rear dif hum when turning at idle
Old May 8, 2006 | 12:06 AM
gdk's Avatar
gdk
1999 f150 4/4 changed clutch pack because of chatter now it hums when turning at idle changed clutch second time and still the same now they want to change iner housing any one else with this problem!
Old May 8, 2006 | 12:14 AM
dwsf150's Avatar
Was friction modifier used in the fluid? I soak the clutch packs in modifier before install. then add a second bottle to the fluid. There also is a special tool to find the right selective shim for each clutch pack to make sure they are not set up, too tight.
Old May 8, 2006 | 10:55 PM
gdk's Avatar
gdk
yes the cluch pack was soaked and one bottle was added worked great for about 10000 km then it starts allover again. the ford service guys figure that its the inner housing.The hotter it gets out the louder it gets.
Old May 10, 2006 | 02:24 PM
dwsf150's Avatar
Make sure the latest clutch design was used. They were changed several times. I've also put in thinner selective washers so the clutches will slip easier on problematic diffs. Down side is the clutches slip easier. The cheap route would be change the fluid and put in another bottle of modifier or just add the modifier.
Old May 29, 2006 | 12:00 PM
zx12-iowa's Avatar
I will be towing a little bit with my chatter back there. How much of an issue would that be?
