please help with hubs
can someone tell me the process of removing the 3 hole autos on a 95 f150.if someone has illustrations or pictures of where the snap ring would be great.i am going to convert it to warn manuals but i have never messed with hubs before , but i have done just about everything else on this truck.any advice or help on the install would be great.
After removing the three bolts holding the cap on remove the cap. There will be a retainer ring on the ID of the rotor/hub about 1/4 inch from the end of the rotor/hub. The ring is tough to remove due to part of the auto locking hub sticking out past the end of the rotor/hub you can use a pick or a small pocket screwdriver to remove it. After removing the ring the hib will pull out.
