limited slip or a locker for the front.
Old Mar 30, 2006 | 11:49 AM
97on37s's Avatar
What would be better to put in limited slip or a locker for the front axle? What does everyone think?
Old Mar 30, 2006 | 12:44 PM
JMC's Avatar
JMC
25 Year Member
A limited slip will not afford the same traction as a locker. When in 4x2 mode it is a mute point so the only other consideration is when driving on slippery roads with 4x4 engauged. Normally a limited slip will allow the clutches to slip when rounding a corner. Depending on the design a Locker will click when disengauging to allow the wheel on the outside to travel farther than the inside one. This clicking could be transmitted back through the steering wheel giving the impression that something is broken. If I could afford it I would get a selectable locker. One more thing, the locker or LSD may cause the front driveshaft to turn all the time. If it does, milage may suffer becasue the drive shaft is turning and it will also turn the chain in the transfer case. That will also create more noise.
JMC
Old Mar 30, 2006 | 03:31 PM
jhoparmy's Avatar
If you go with the Detroit Tru-Trac limited slip in the front you won't have the problem of the driveshaft turning even in 2wd. The tru-trac is a gear driven limited slip instead of a clutch drived type. Since you have a CAD (center axle disconnect) you want the tru-trac. Even the selectable lockers, (air locker, e-locker, etc.) run as a clutch drived limited slip when not engaged. Hope this helps.
Old Mar 30, 2006 | 07:28 PM
97on37s's Avatar
ok thanks it does help
Old Mar 30, 2006 | 10:23 PM
JMC's Avatar
JMC
25 Year Member
The ARB unit is an open differnetial with an air activated lock.
JMC
Old Mar 30, 2006 | 10:54 PM
97on37s's Avatar
JMC how much does his differental cost?
Old Mar 30, 2006 | 11:24 PM
JMC's Avatar
JMC
25 Year Member
Check the ARB site for the closest dealer to you. I did quick search and http://www.rocky-road.com has them for $689.00 + shipping. You will also need a compressor $218.00. Not cheap by any means but very effective off road.
JMC
Old Mar 31, 2006 | 11:56 AM
97on37s's Avatar
OK thank JMC
Old Mar 31, 2006 | 04:50 PM
Rock Krusher's Avatar
Both the Eaton E-locker and the ARB unit are open diffs when not locked in.
The Detroit Electrac and the Auburn Ected are both limited slips when not locked in.
Old Apr 3, 2006 | 11:54 PM
03fx4F150's Avatar
I will getting the eaton E locker
Old Apr 16, 2006 | 11:07 PM
drewg350's Avatar
I've always had Detroit in rear and ARB up front. This combo can't be beat as far as traction. I've had great success and never a single problem on any truck that had this combo. I plan on doing the same on my current truck if I get into changing gears and lifts.
Old Apr 17, 2006 | 05:58 PM
93F150's Avatar
I have the eaton up front and the detroit out back in my 2000
Old Apr 28, 2006 | 06:18 PM
Klitch's Avatar
i slapped Powertraxx lock right systems.
http://www.central4wd.com/inventoryd...;folder%7C5519
works great for toying around. they lock right up in the front and pull you around where you point like its a real locker, they DO make road noise and a bit of banging around when it ratchets and re-locks.
ALSO from personal experience with my 97 F150 8.8 / 8.8IFS: when you get the PTX unit for the 8.8 reverse, check to see if theres a clip, looks like a paper clip thickness square shaped spring clip. if it is not supplied i would call up the manufacturer and ask if they can send you one. at this point you will learn they have.. ahem.. "issues" regarding the 8.8 IFS unit, they swear up and down they dont make it (but youve got the damn box in your hand that says otherwise)
it may not be necessary for you, but it was for me. i had no clue how i was going to secure the shaft in place with the stock hardware c'clip because it just plain didnt clear anything internally.
just my personal experience with this setup. still a good cheap alternative
Old May 3, 2006 | 06:32 PM
BigSexy's Avatar
Would it be possible to use the Eaton with an Expy with the AWD control-trac? I want to have the option to put it into 2wd to try and save on gas.
Old May 5, 2006 | 03:06 PM
93F150's Avatar
The eaton is "open" when the button is not pushed, which is exactly what you have now, so it will work the exact same as you have now. Your expedition does not have a front axle disconnect which is needed to not have so many things turning.
