** Drivetrain Slipping/Popping **
Old Mar 22, 2006 | 10:36 PM
99taws6's Avatar
I have a 00 Expedition Eddie Bauer that has the 5.4 and is A4WD. Recently the vehicle has developed a kind of slipping feeling when I am under light acceleration. It doesn't matter what type of speed I am doing it will do it at about 30% throttle till about 70% and then it goes away till the vehicle shifts and lowers the rpms. It feels like power is being taken and then given back. Almost like something is slipping.
I have checked all the drive shafts and U-joints all seems fine. I had a leak on the transfer and I thought maybe the fluid could be the problem. The fluid was full, but I drained it and refilled it anyways. The fluid was a little dark and burnt, but not like I have seen in burnt trannies.
What should I check next to try to fix this problem. I am a broke military guy, so the more I troubleshoot/fix myself the better. BTW vehicle has 109,000 miles on it.
Thanks in advance for your help....
Old Mar 23, 2006 | 08:41 PM
metallion's Avatar
Check your transmission fluid level and condition. Might be your concern there. Also, was your transfer case overfilled. If so, you might have a bad seal between the trans and transfer case allowing tranny fluid to leak into the transfer case. Good luck!
Old Mar 23, 2006 | 09:17 PM
99taws6's Avatar
I have checked the transmission fluid level. I will change it this weekend just to rule that out.. It has almost totally got better.. seems the fluid change in the transfer was what it needed.. Just took a few miles to get the clutches full of the new fluid.
I will update if it gets bad again... Thanks...
