8.8 rear end
8.8 rear end
I have just replaced the spider gears and side gears in my rear end and now it makes noise when I am coasting. Somebody told me that I need to tighten the pinion nut to make up for the space the crush ring made, I just wanted another opinion. Also, can somebody tell me the size of the pion nut. I think it was 28mm but I dont remember. Thanks.
"Make up for the space the crush ring made?" Huh? You didn't mess with the crush sleeve or the pinion gear, did you? I forget, but I think the pinion nut is 1-1/16" or 1-1/8", it's been a while since I've done one.
Okay, did you reuse the old crush sleeve or use a new one? How'd you tighten the pinion flange? Sounds like you've got a pinion bearing preload problem, either too much or not enough.
Originally Posted by cityhick87
I bought a new crush ring. I tightned it as much as I could. I have been driving it around a little to crush it. Now I plan to tighten it up. Hopefully, that will take the noise away.
