Rear Axle Ratio Code
Same code here... 3.55 LS... what do you all think about 33 or 34s with that gear set... or should l just do 32s... (95 % dd driver just wanted something bigger then the 30s).... I know going from 30 to a 34 the 3.55 gears would be like 3.13 after that... but i drive about 75% of the time at 60 mph but up and down hills. what do you all think? and what tires can i fit with no cutting and no lift on a reg 4x4 Screw?
IMO, it'll bog down pretty good on the hills with 33's or above and 3.55's..... I've got 31" tires (LT265/75/16) and it was noticable, but tolerable in my case......
I did have to re-cal the VSS with a one tooth gear change (stock 20 tooth to a 19 tooth). But, on your trucks, you'd have to have the comp re-programmed because you don't have the $10 VSS gear...
There are lots of trucks out there with 3.55's and 33's (285/75/16), so it must be tolerable, but I tow a #4500 TT and I know I would not be liking them while towing...
Perfect combo would be some 4.10's with a 34x12.50x18 wheel tire combo.... I saw them in my latest Summit catalog with our bolt pattern (5x135mm), BFG AT's and some Centerline wheels for just under 2 grand ($1995) for a set of 4..... Did not include center caps however... Whatever to that! Anyway, I digress.......
Good luck!
Mitch
Good luck!
Mitch
