Hub Nut size?
Old Dec 22, 2005 | 01:41 PM
99Flare's Avatar
Hub Nut size?
Looking to find out what the hub/axle nut sixe is on my 99 F150 4x4. Need to change out hub/bearing assembly. Need to know so I can purchase the socket when I pick up the part? Thanks for the help.
Old Dec 22, 2005 | 11:46 PM
99Flare's Avatar
Talking hub nut...axle nut...spindle nut
OK, I got the size! Its a (1-3/8). Here is text for anyone who tries a search like I did without finding an anwser. hub nut.......HUB NUT.....axle nut...AXLE NUT...spindle nut...SPINDLE NUT...... THE ANWSER IS ( 1-3/8)! Hope this saves you a extra trip to the tool section to get the right one the first time.. GOOD TIMES!
Old Dec 23, 2005 | 08:48 AM
GIJoeCam's Avatar
Originally Posted by 99Flare
OK, I got the size! Its a 36mm. Here is text for anyone who tries a search like I did without finding an anwser. hub nut.......HUB NUT.....axle nut...AXLE NUT...spindle nut...SPINDLE NUT...... THE ANWSER IS 36mm! Hope this saves you a extra trip to the tool section to get the right one the first time.. GOOD TIMES!
Yup.... didn't get to it in time. Sorry. (I only check the baords in the AM)
-Joe
Old Dec 23, 2005 | 09:08 PM
99Flare's Avatar
Old Dec 24, 2005 | 06:08 AM
GIJoeCam's Avatar
Im editing my earlier post.....the size(36mm) I posted is incorrect....it will not fit the nut its too large....its got to be a 34 or 35...Ill update when I get the correct one. I just now found out as I went to take it off. I was assured by a ASE Certified Mech it was 36! The parts house is open in the morn so I WILL get the right one.
I could have sworn mine was a 36.... weird....
-Joe
Old Dec 24, 2005 | 11:57 AM
99Flare's Avatar
Old Dec 24, 2005 | 10:44 PM
Sparky604's Avatar
i used a 36mm for mine. it fits a little loose but it will work. the 36mm still has plenty to hold onto and the nut is something like grade 10 so it takes alot to mess it up.
35mm is nearly impossible to find. i'm sure there are places on the net that sell them but nobody had one when i needed it.
Old Dec 25, 2005 | 12:38 AM
99Flare's Avatar
1-3/8 Its All GOOD!
Old Aug 14, 2016 | 10:04 PM
BaryMcauner's Avatar
NEITHER 35mm or 1 3/8" FIT
I have both sockets, and neither fit my 1999 F-150. Headed back to get a 36mm or 1 1/2" right now. 3rd times a charm I hope.
Old Aug 14, 2016 | 10:08 PM
Roadie's Avatar
The guy at Autozone told me it was a 36mm for my 2002 and that will work but is a little loose. The correct size is 35mm. Now, I have both.
Old Aug 18, 2016 | 03:11 AM
I picked up a 36mm at O'reilly's. On my way home remembered it needed to be a deep socket. So I stopped at Auto Zone and picked up an 1 1/2" socket.(they didn't have 36mm). It did the trick, but it was a loose fit. My new axle came with a new nut. 35mm fits perfect.
