4:10 in TTB???
Old Dec 1, 2005 | 11:04 PM
usedtodrivechev's Avatar
4:10 in TTB???
I have a 94 f150 4x4 and want 4:10 gears. I read one reply to another post saying it wont work? I have only 50,000 miles on the truck and dont want to waste money having to find a dana 50 or 60 with 2, 3 or 4 times the miles. Let alone rebuildind it and trying to weld leaf mounts onto my frame to make it fit. I have the twin i beam up front and a 8.8 in rear. i have 3:55 gears and i am about to buy larger tires. Can i put any lower of a gear in my axles with out swapping them for new ones?
Old Dec 1, 2005 | 11:39 PM
brown255's Avatar
I am going through the same thing right now with the gears and tires and limited power. Here is the best thing I have found to help tell you were your power band will fall with different size tires and different gear ratios http://www.4wheelpartsperformance.com/html/calc.php Also you might want to read my post about the 3:55 to 4:10. As far as rebuilding that 8.8 and finding the gears that fit. I have found all kinds of gear makers for my 8.8 such as Yukon, Motive, Richmond, ford racing.
Old Dec 1, 2005 | 11:57 PM
thanks
thanks that is a very good site to know. i just need to know if the twin i beam will accomodate 4:10 gears. i dont want to swap the axle.
Old Dec 3, 2005 | 03:20 PM
Rock Krusher's Avatar
Yes you can put 4.10's in it. You can go with 4.56's if you want to.
Old Dec 4, 2005 | 04:58 PM
sweet thanks
