gear ratio question a.s.a.p.
Old Nov 13, 2005 | 09:23 AM
Sabatour's Avatar
Hi all I need this question a.s.a.p. due to that I have tentivly ordered a truck. But I havn't desided on a colour. But sleeping on it last night brought me to another question.
This dealership has a cool off road option. They call it the Baja pakage. It comes with 35" BFG's muds 4" lift duel exhaust and speed grill.
My question to you all is. Should I go with the stock 3:55 gears or order the 3:73 gears the truck is a 2006 supercab f150 xlt with the 5.4 in it 6.5 box
thanks in advance
Gerry
Old Nov 13, 2005 | 10:08 AM
Churchkey's Avatar
35" is a tall tire you may want the lower gear. Will the dealer correct for speedometer error with the larger tires? Installing larger tires will result in the speedo reading slower than actual speed.
Old Nov 13, 2005 | 10:22 AM
faawrenchbndr's Avatar
With 35's I would be wanting 4.10's. Something to think about!
Old Nov 13, 2005 | 02:00 PM
Sabatour's Avatar
Yes they will set up the speedo so it is correct. 4:10 gears are not an option from this dealer. Thanks for the info. Looks like I will be going to the 3:73's from your responce and other places I have asked the question. Also to let you know this truck will be leased so I can't swap 4:10 in later unless I plan on buying it in 3 years.
Sabatour
Old Nov 13, 2005 | 10:38 PM
huntingnfishing's Avatar
you might want to think about upgrading the braking system with those 35's..... Just a thought/opinion.
Old Nov 14, 2005 | 02:22 PM
Sabatour's Avatar
gear ratio
thanks for the info. But I will have to keep it stock. This truck will be leased for at least 3 years. I'm going with the 3:73 gears. When I get it I will put a pic on this site.
Sabatour
Old Nov 14, 2005 | 02:53 PM
StngStr's Avatar
yep...given those options, get the 3.73's. Personally, when I get my 35's, I'll be also going with 4.56's.
