Power Stearing
Old Nov 1, 2005 | 09:55 PM
BLUEWORKHORSE's Avatar
Power Stearing
Ive got a power stearing leak. Its on what i believe is a high pressure line that is attached to the power stearing pump. Its leaking right at teh fitting. Has anyone had a problem like this before and is it hard to fix. Do you think i need to replace the hose or the power stearing pump.
Ben
Old Nov 1, 2005 | 11:59 PM
1Ford-Fan's Avatar
Hey Ben,
If it is leaking past the threads of the "nut" on the end of the high pressure hose there is a seal ring that you will need to replace if it is leaking between the nut and the line you will need to replace the hose. The hose replacement is not hard. I hope this helps.
