Pinion Seal problems
Old Oct 26, 2005 | 12:38 PM
troykshafer's Avatar
Question Pinion Seal problems
Under my truck there is diff oil slung all the over the underside. There is a small bead of oil that will run out of the pinion right after i park it. Now it doesn't send out a spray or anything that bad, but it's bad enough that after a drive to work it has covered the underside half way up the drive shaft.
Now I just thought, hey i'll replace the pinion seal and life will be good. But then i was told by that it could be the universal joint going out... if it was the universal wouldn't i notice shaking or vibrating at high speeds?
Old Oct 26, 2005 | 01:33 PM
bigtruck311's Avatar
crawl under there and try to move your drive shaft in all derections to see if you have any play in the u joint, good luck
Old Oct 26, 2005 | 09:08 PM
max mitchell's Avatar
Yes, check the U-joints, but they only contain a small amount of grease. They don't "sling out differential oil", "run a small bead of oil out the pinion" or "include enough lube to cover the underside halfway up". By the time the factory U-joints are shot, they're usually almost dry. Leaking pinion seals are a very common problem. I would do a search because there is already substantial information in the archives. You will find several opinions on the replacement procedure. Typically, you'll see a gear oil trail leaking down the front of your rear end below the pinion seal.
Old Oct 28, 2005 | 12:28 PM
Yeah, it's all over underneath the pinion, i'm guessing as it comes out some of it is being slung on the underbelly. Also a small pool forms after driving it then parking it. By small i mean about the size of two quarters.
I want to get the seal this evening and begin tear down tomorrow morning. The problem i'm having is there are different size seals listed at the different part stores websites. I have a 5.4L offroad lariat, there's an 8.8, 9.75, 10.75... i really don't want to trust the kid behind the counter to get it right.
Old Oct 28, 2005 | 12:43 PM
you should have the 9.75, you can look back at the axle is it kinda shaped like a stop sign? i am 99% sure that you have a 9.75 with a 5.4 only the 4.6 has the 8.8 and the 7700 F-150s have the 10.75, good luck
Old Oct 28, 2005 | 12:52 PM
7700? Which one is the Heavy Duty? I assumed i would have that because i have the towing package.
Old Oct 28, 2005 | 12:58 PM
I have tried using my VIN to find out information on my truck but i can't find a good website... any one know of one?
-realized my vin won't tell me, i'll have to look when i get home. I thought i would be able to find exactly what was on my vehicle.
Old Oct 28, 2005 | 02:29 PM
the 7700 is the light duty F-250 looks like a f_150 body but it has tougher suspension and better payload capacity, you would know if you had one, you most likely have the 9.75 axle,
Old Oct 28, 2005 | 02:32 PM
How would i know if i have one?
besides looking underneath. I know i have the heavier duty transmission that is an option on the F250.
Last edited by troykshafer; Oct 28, 2005 at 02:43 PM. Reason: i don't think quick enough
Old Oct 28, 2005 | 06:51 PM
Peacemaker's Avatar
Here you go.
http://www.autozone.com/servlet/UiBr...%7ENONE%7C%7EB
Old Oct 28, 2005 | 06:58 PM
garo1's Avatar
I just had my ring and pinion replaced. After driving the truck for 2 days I noticed a vibration and a leak around my pinion seal. I took it back today and they found out that the u-joinrts are bad and they need to replace the drive shaft. The parts won't be in unbtil next week so they have torn down waiting. I hate not having my truck.
Old Oct 28, 2005 | 08:40 PM
fordninja's Avatar
If you have the 5.4 look to see how many lug nuts you have. If you have 5 then you have the 9.75. If you have 7 then you have the bigger one.
Old Nov 6, 2005 | 08:35 AM
I'm fairly sure ya'll are right, the code on the tag is
s 919 0
155 9 75
9L22
I'm not sure what all that means but i recognize the 9.75.
thanks for all the help guys, i'm hoping to do this today so i can start driving my truck again, the universal joint doesn't budget (THANK GOD!) and it's a sad sight seeing my truck just collecting leaves.
Old Dec 2, 2005 | 09:32 PM
Thumbs up Fixed
Thanks to all who gave input. I pulled out the drive shaft and replaced the pinion... while i had it torn down i decided to replace the universal... my first. Luckily my dad used to be a mechanic and walked me through it. It really wasn't that hard... but i can see where the pain would be. Getting the old universal out. Luckily we have a packed garage with a hydrolic press and it was a peice of cake. I bought the heavy duty universal.
After getting the universal out we found that two of the ends were developing several flat spots. The pins were also bone dry and looked a little funny. not sure if this is normal for 150k. After replacing both i have had one leak, even after using the wrong RTV on the back plate... oops. I used black but not the heavy duty made for high temps.
I wanted to thank everyone who responded... this website has been great for me since i bought my truck and i've recommended it to my step dad and brother who both just bought 2006 F150's... i'm jealous... thanks again!
