Front Differintial
Old Jul 15, 2005 | 07:52 AM
02KR's Avatar
Front Differintial
Does the front also take the same type of additive as the back rear end?
Also if I do not have a LS diff. then do I need the additive for the rear end?
19 in the door frame is non LS, am I correct?
Old Jul 15, 2005 | 04:04 PM
bigtruck311's Avatar
no you dont need any friction modifier for your front axle unless you put in a LS in the front that requires it, no aditer is needed in your aplication front or rear unless a LS was put in
