Rear end gasket??
Old Jul 18, 2005 | 06:18 AM
fordman4life's Avatar
Buck, There is a dope hole plug on the side of the housing.It is also magnetic, check it for chips also...
Old Jul 20, 2005 | 03:22 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Well i am finished after fighting with the plug for filling the unit (had to use heat) I also had to replace the cover plate due to it being rotted i have it all done. I thank you guys one and all for the continuing info i get here from everyone. By the way the oil was wayyyyyyyyyyyyy bad looked like chocolate milk when i emptied it.
Old Jul 20, 2005 | 05:50 AM
No problem. Glad to help!
Old Jul 25, 2005 | 05:00 AM
cafasco's Avatar
No wonder my cover leaked and I had a mess inside the housing. The case, gears, bearings, and cover were all coated with a sticky residual gook (whatever is left of the RTV).
RTV silicone gasket sealer is NOT compatible with synthetic oil. Do NOT use it. Instead, use "Ultra Grey", "Ultra Black", or "Ultra Blue" by Permtex(sp?). You can get it just about any where (Auto Zone, Napa, Schucks, CarQuest, etc). Wal-Mart does not carry any though. It should be hanging real close to the RTV. One tube is about $4 and will seal 5 or so diff covers.
Old Jul 26, 2005 | 04:46 AM
I used RTV blue and it shows no leaking. Try getting off the filler plug now thats a challange!!!!
Old Jul 26, 2005 | 06:22 AM
JMTruck's Avatar
Check in the front and right side of the differential.
Old Jul 26, 2005 | 06:47 AM
cafasco's Avatar
Hit it with some PB blaster or other penatrating oil, then let it soak for a while. Use a 1/2" torque wrench with a 3/8" reducer to persuade it loose. If it's still not co-operating, keep applying the oil for a few days. She'll come loose eventually.
