The Ring
Old Jul 6, 2005 | 01:46 PM
Chrishulgan's Avatar
The Ring
Mike and I purchased a 1998, F150, 4.6L, 4X4, 3.55 LS for his daughter. I am in the process of going through the truck and changing all fluids, belts, hoses, etc. While changing the rear differential fluid I noticed a toothed ring mounted to the ring gear. Near the top of the differential is a sensor, which appears to a Hall Effect sensor. Is this used for speedometer correction? Given a stock baseline, if the pulse did not match a correction factor would be applied (??)
Old Jul 7, 2005 | 12:12 AM
fordninja's Avatar
That ring is used for rear abs. The speedo gear is in either the trans or the transfer case depending on if you have 4wd.
Old Jul 7, 2005 | 01:07 PM
Valuable Info
Thanks for the information. This also explains why I could not find the ABS sensors on each rear wheel.
Old Jul 8, 2005 | 10:40 PM
subford's Avatar
It is the Vehicle Speed Sensor (VSS) sensor, its output is used by the
odometer, speedometer, rear Anti-lock brakes, and the powertrain computer.
I have no sensors on the tranny for speed, just the VSS sensor on the
rear-end on my 1995 f-150.
Old Jul 9, 2005 | 08:18 PM
flaresidejay's Avatar
The speed sensor in the diff. is only used for ABS. Your VSS in a 98 is on the rear of the tranny, on the drivers side. The VSS has a gear connected to the outputshaft of the tranny. This is where vehicle speed is measured.
Old Jul 11, 2005 | 03:44 PM
Thanks!!
