first time changing dif fluid
hey evryone i am going to the store tomorrow to buy some dif fluid and the limited slip stuff. i have 3.55 LS in the truck.. should i take the cover off to drain it or just suck the old stuff out? how many bottles of the special limited slip fluid should i use.. i have heard one bottle and i have heard 2 bottles from the forums. and last but not least... whats a decent brand of new fluid? weight? and how many??? thanks guys for any help!
You can order the fluid from Jeg's or Summit.
This is the stuff.
http://www.jegs.com/cgi-bin/ncommerc...50&prmenbr=361
This is the stuff.
I used Amsoil 75w140 ($12/qt x3) for the rear and 75w90 ($8/qt x2) for the front (4x4). Got it from a GIJoes off the shelf. I added one bottle of friction modifier from the Fords part counter ($5) even thou the Amsoil said it was ok for LS rear ends..... My LS works great with 143k miles on it!!
Mitch
Mitch
I am not a mechanic (diclaimer)
When I changed mine, I did remove the cover, and let it drain completely, wipe out any excess grit, clean inside of cover.
Used a black RTV type sealant (caulk gun size) and made the seal around all of the bolt holes etc..
Put the cover back on and hand tightened. Let sit overnight and then completely tightened, refilled.
check for drips.
It seems to have worked.
check for drips.
well finished the job.. it wasnt hard at all. i ended up going with mobile 75w 140 jsut because no other place int eh area had 75w-140!! i didnt want to spend the whole pay check buying it at the dealership ha. i did add 1.5 bottles of the friction mod and used the black rtv for a gasket.. pretty simple except holding the bottles to get the lube in the hole sucked after a while! haha thanks for the help guys
