syntnetic lube in transfer& front and rear drive
I am going to put a synt lube in and see if my mpg go up. has any one tried it?
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*tow pkg, 17 inch wheels
*herculiner,remote start
*flowmaster, air box mod
*bfg ko's A.R.E. cap
*sony 10 disc cd player
****mods to come*********
LS for front diff
wms air tube
super chip
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
LS for front diff
wms air tube
super chip
The rear differential is synthetic (and 'never needs to be changed unless the axle is submerged under water'..owners manual)...and I also thought the rest had synthetic also...but I am not 100% sure.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
[This message has been edited by Dustoff (edited 02-24-2000).]
Steve. Changed my drivetrain fluids to Amsoil. Didn't notice a big difference but the added protection is a big plus.
Henry
99 F-150 XL 4x4. RC Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector. rhino liner and a cool white shifter ball.
Henry
WRT "fill for life" fluids, consider this. A gear set or assembly will go through a run-in period where the surfaces of the gears will wear very slighty to accomadate the profile of the mating tooth surface. This run-in produces very fine shavings that will remain in the oil bath unless purged out.
It is standard proceedure in critical gear drives to flush the system with clean oil after a set period. I have always followed this thinking automotive transmissions, transfer cases, and differentials. You will be surprised at the accumulation of metalic material you see!
HMMMMM...... i will have to check my owners book i didnt think that it had syn fluids in it..... but what about the transfer case??? Thw fluid is free we buy it here buy the drum, is there a additive that has to be added to the rear for limited slip with the syn??? I know there is a additve when you use reg lube but not sure with syn lube. One other question i heard that if you order the ls option you get a ls unit in front drive as well has any one had the front drive apart to check??? It has been my experiance that you do not get a ls unit in front .
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*k&n air filter
*superchip
synth lube in drives& transfer case.
removing stock cab steps& installing westins.
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*k&n air filter
*superchip
Well i spoke to the dealer 2000 come with synt in the front and rear drive's and the friction modifier(additive) has to be use as well if you have a limited slip. The transfer case use the mecron 5 in it. On the ls being in front drive as well they said they had not ever seen it stock. So...... i answered my own question thanks to those who did offer in put though.
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*k&n air filter
*superchip
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*k&n air filter
*superchip
Just a note about fluid "flushes" and the lifetime crap:
I had my gears changed and the front pinion gear has a few "chips" missing near the point of the gears. These were undoubtedly floating around in the lube. I've now got ~500 miles on the new gears and the lube will be changed Thursday.
Neal
1997 4x4 Expedition- 4.6L, true dual exhaust w/glass-packs, K&N air filter, SuperChip, airbox mods, Edelbrock shocks, 285/75R16 BFG ATs, Optima "T-Bone" wheels, 4.10 gears, Auburn LS, Clarion In-dash CD player, Smitty Bilt push bars and nerf bars!!
2000 4x2 F150 XLT Reg. Cab LWB- 5.4L, Tow Pkg, 3.55LS, CD player,Remote Keyless Entry, Sliding back glass, Special Appearance Pkg.
http://members.visualcities.com/NoMo
Neal
Nomo: Are the tooth chips the Reason for the gear change, or did you notice them After the gear change?
If the latter, have a good gear man check the set-up, as chipped teeth can result from a bad set-up.
It was after I had the gears changed to compensate for larger tires. I got to keep the factory gears. The original front pinion has several "tips" missing. The tech didn't say anything about chunks in the fluid, but the front wheel bearings were totally shot- big gouges in the rollers with only 38,000 miles on them.
