Front wheel bearing
Old Jan 19, 2005 | 12:20 PM
tango5's Avatar
Angry Front wheel bearing
Hi folks, Ok i decided to change the balljoints on my 93 F150 4x4 and everything went as planned until i got to the point of putting back the disk bearing. This is were i need your help, because i can't remember which end goes in first.... On the back of the Rotor the small end goes in first (i know this because i did not remove it) but should i be inserting the big end of the bearing or the small end of the bearing for the other side?
Any help would be greatly appreciated.
Tom
Old Jan 19, 2005 | 10:25 PM
powerstroke73's Avatar
If you look inside the hub assembly there is a race that the bearing fits into. The bearing is only supposed to go in one way and is somewhat obvious if you can see the race.
Anyways, as I recall the D44 axles have the bearings have the tapered ends facing each other kinda like this > < . There is one inner and one outter bearing and if you look at the hub you'll see the tapered bearing race it fits into.
