cooling system and brakes
Old Oct 17, 2004 | 01:29 PM
intocable's Avatar
Exclamation cooling system and brakes
TWO QUESTIONS
1) Well I am a newbie around here and I own a 1998 Ford F-150 4.6 V8 4X4. When I was coming home from Texas to Nebraska, I had my air condition on and then I started seeing like this mist or fog coming out of my vents in the cab. The smell was fom antifreeze. Now I have added a 'stop leak' additive to the coolant and the smell comes back like in a week or so. It smells more if I turn on my heater. Can anyone help me on what is the cause of this? Thanks I will appreciate any response.
2) I recently changed my brake disks and brake pads. Now when I press on the brakes while driving, I get this squeaking sound. Anyway to get rid of it? Thanks again.
Old Oct 19, 2004 | 10:46 AM
max mitchell's Avatar
1) Possible bad heater core.
2) Possible new brake pad composition.
Old Oct 27, 2004 | 01:51 PM
spridel's Avatar
Re: cooling system and brakes
Did you use any 'anti squeal' compound? This is the red or blue goop you put on the back of the pads to eliminate vibration - which you hear as squeak. If there is no vibration in the brake pedal (pulsing), you can disassemble your brakes and put it on, then re-assemble. That should take care of the squeak.
Also, make sure the sliders are properly lubricated. The brake caliper may hang if it binds up.
