Which brand of 4.10 gears
I want to change my 3.55 gears to 4.10 on 2001 F150 Supercrew 4x4 with 33" tires and was wondering what you guys recommend. Four wheel parts has genuine gear with a lifetime warranty . any comments or brand recommendations. Thanks
I'll echo Mikeintx on the Ford gears. I did the 3.55 to 4.10 with the Ford Racing Performance Parts (FRPP) gears and was very impressed. Easy to set up and very quiet. If you have the 9.75 gears you might be out of luck though. I think they only offer them in 8.8".
What they mean is that the Ford Racing gears are manufactured to the same specifications as the stock Ford ones.They require similar shimming and comply with factory noise standards.
Here is what's involved:
www.ring-pinion.com/tech/yukoninst.pdf
