1998 - 4 WD problem
Old Aug 24, 2004 | 01:17 AM
fordguy1960's Avatar
Exclamation 1998 - 4 WD problem
98 f150 5.4 ltr supercab 4x4 85,000 km or 55,000 miles
used 4x4 low and had difficulty dis engaging -- had to disconnect transfercase motor several times.
able to disengage from 4 wheel hi now -- have not tried 4 w low again.
any ideas
Old Aug 24, 2004 | 06:05 AM
ConcreteGuy's Avatar
I had a problem cause I did not know how to use my 4x4 button...It has no neutral on it...
If your truck has this type setup ?? I was told to place the transmission in neutral and put my foot on the brake...Then at a full stop , then I could move from 4L to 2H or 4H...Watch for the light on the dash to see what setting your in...Oh...You do the same thing to go into 4L as well...
Hope that helps you some ...
