Tuba sound under my hood
Did a quick search and came up with nothing remotely close. Lately, I get a bass horn sound from under my hood when I remove some pressure from the gas pedal. It seems that the sound only happens after the torque conver has locked as I dont hear the tuba under about 40MPH. Nothing seems to have changed, no codes, nothing. I have noticed that every once in awhile, it will seem like the trany is hunting when going into torque conver lock, and as soon as I let off on the gas, the torque convert lock OK.
I have a 2000 Lariat, 5.4, 3.55 gears (as near as I can tell), and just passed 70,000 miles.
Any ideas???
Thanx in advance
Larry
Any ideas???
Thanx in advance
Larry
Sounds like the torque converter is going bad or it may just need a fluid change (with the rest of the tranny fluid). When was the last time you had it changed? Also, I "assume" you checked the fluid level?
