clicking/ticking noise from rear
Hi..trying to get some information before I bring it in. I have ticking/ pinging /clicking sounds coming from my rear end. The best I can describe it is if aluminum lugs are lose and you get that mettalic pinging sound. I have a '95 f-150. I did a search here already:This noise happens when going straight as well as turning. 13 months ago, I had the thing rebuilt with the exception of the pinion--mechanic said it looked fine. I had the inner and outer bearings done, the rider bearings, spline, flange, pinion bearing and cone, axle bearing asemblies, axles, etc. Any ideas, given this lame description?? Also, do I stand my ground if mechanic says guarantee has run out? Seems for $1,200 bucks, components shpuld last longer than 1 year and less then 30K miles. Thanks in advance
Ah, temp to the rescue!
No- it's completely random--kinda like a rock in a hubcap sound. Hopefully it's not a tooth in a diff. sound. Sometimes it's completely silent, other times it chatters hard (though no vibration felt) and sometimes it just sort pings intermittenly. I'd say it's a bearing if they all weren't replaced recently, given the area it's coming from, but it's not a scraping sound. Again, I turned the hub and didn't hear or feel nothin'. Thanks.
yeah...
Aluminum wheels, w/ dust covers (they are tight. A metal mud flap was loose and I snugged that up). Also has leaf springs. I jumped on the bumper, shook the wheel to look for play..I'm baffled too. Drove it 1.5 miles to my mechanic's today and it didn't make a peep. Here we go.
