Rear End Tremor READ!!!!!!!!!
Old May 16, 2004 | 09:38 AM
smkeater's Avatar
Exclamation Rear End Tremor READ!!!!!!!!!
I had my rear differential recently repaired at the dealer for stuttering at start and in a turn. BAsically they replaced the clutch paks and it solved the problem. After to talking to a my Ford service writer he explained that it a common problem in explorers and Expeditions and that there is a repair kit for them. He never experienced the problem in a f150 and didnt know if a kit was available for it. If you press the dealer enough you can get the clutch paks replaced if it still is under warrany. Hope this helps!!
Old May 28, 2004 | 01:41 PM
LightningCrew's Avatar
Man, wish I had come to this forum earlier, of corse I did not know what was wrong with my truck. I just had this same problem in my 2001 SCrew with 112K miles on it. Dealer said it appeared to have water inside and needed to be serviced. $117 later and the problem is gone.
Old May 28, 2004 | 09:30 PM
Roadie's Avatar
There is a technical service bulletin on this. It does cover F150''s. I got a copy of it from the dealer. I think it is in NC and I am in WI. I published the content of it on this site a couple of months ago.
Old May 31, 2004 | 01:50 PM
Can you post a link to the service bulletin or tell me where to find it or what the number of the bulletin was?? They did not fix the problem and I have to take it back tomorrow.
I searched under 2001 F150 and did not find the service bulletin.
Old Jun 4, 2004 | 09:58 AM
Ends up it was the clutch packs in the rear end. $700+ to fix it!!!
Man, I am ready to give up on Ford!!!! None of my GM vehicles ever gave me as much trouble as this truck has!!
