COP System CHECK
2001 Super Crew 5.4L...
Hesitation (miss) caused engine light to come on (stays on)... Hand-held scanner said #1 cylinder misfire....
Q. Do I need to pull out the coil to check primary Resistance ???
THANX, v....
THANX, v....
Being the #1 cyl. I would think that you should be able to check the resistance by simply unplugging the coil and checking it. That being said I would follow advice above and pull it and the plug. Moisture can be a problem and a crack in the plug can cause a misfire as well. Engine forum will get you better responses ( probably from a dozen people with the same problem)
