Adding rear discs
Old Feb 1, 2000 | 03:21 PM
J-C's Avatar
J-C
Cool
I think the rear disc gives you the capability of "ABS on the rear" that is standard now. That capability involves Master Cylinder changes under the hood.
Good luck...
Old Feb 1, 2000 | 03:56 PM
fomoman's Avatar
Post
Mine is a Lariat, so I already have 4 wheel ABS, does anyone know if the ABS controls and master cylinder are the same for disk and drum? Also, I plan on taking the limited slip diff. from the same axle to replace my open one, they are both 8.8s so I assume this is no problem. Thanks for any replies.
Old Feb 2, 2000 | 12:45 AM
fomoman's Avatar
Question Adding rear discs
I have a 97 F150 4x4 with 4wabs. I want to add rear disc brakes from a 99. Is this a straight forward bolt-on?
