'99 7.3L diesel not starting
While not an F150, at least it's a Ford. My boss has a '99 F350 crew/long 4x4 7.3L auto. Often, the we have to bypass the starter solenoid with a screwdriver to get it started while in park. Recently, because of another problem, we found out that it starts just fine in neutral. My boss has had me replace the starter solenoid (a few times) and the glow plug solenoid (once) so I'm pretty sure they're fine.
Anybody know why it would start in neutral and not park?
Well done, fellas! I noticed that when the truck wouldn't start in park I can pull up on the lever (with my left hand) and it starts.
So I unpacked my Chilton book tonight. Looks like it's called the Transmission Range Sensor. Zaairman, is that what you adjusted and/or replaced when you weren't going into park? Or did you actually change where the shift lever mounts on its shaft.
