1985 F-150 clutch won't disengage
I have a 1985 300 6 cylinder F150 and I recently replaced the clutch. After replacing the pressure plate, clutch pad, throwout bearing, and the slave and master cylinders, the clutch still won't disengage. We bled the cylinders, and still nothing happened. The slave cylinder extends against the release fork about one inch.
Sounds like the pressure plate-
It may be just stuck or more likely, the TO bearing was the wrong spec and it pushed the levers too far bending them or their might just be a spring collapse.
