Another question about AMP install...
Old Jul 9, 2004 | 03:00 PM
jamzwayne's Avatar
I have a question about AMP installation AGAIN....
2004 STX Heritage - where is the BEST place to run my power wire to the battery at the firewall. I cant seem to find a "rubber plug" to run it, and really dont wanna drill a hole through it.
Any suggestions?
Old Jul 9, 2004 | 03:41 PM
dzervit's Avatar
No answer, just pumping up the 'ol post count. Need to make 500 before I leave work... 7 more to go!
Just drill it you pansy.
ARRGGGGHHH!! Damn only post every 60 second crap! Tic toc tic toc... *click*
Old Jul 9, 2004 | 04:14 PM
hillbillyFX4's Avatar
On the driver's side there should be a grommet, about 1 - 1.5 inches across. Just above the steering column if I remember correctly.
Old Jul 12, 2004 | 09:58 AM
jamzwayne's Avatar
Thats the one I used....worked pretty darn good too.
Old Jul 13, 2004 | 01:01 AM
You'd better put that wire THROUGH the grommet, instead of around the side of it. Once you put that grommet back in, it's going to rub that wire against that bare edge of metal and cause you all kinds of problems. Once that metal gets through the casing of that wire, you got sparky sparky. Bad joo joo.
Just poke an additional hole through the grommet and run the wire through it. When you do that, check the wire and make sure there hasn't been damage done already.
Old Jul 13, 2004 | 09:40 AM
jamzwayne's Avatar
WHOA!
I didnt think of that. Thanks hillbillyFX4.
