Mirror Shake& Wind Noise NTSB Bulletins
Check out the NHTSA site. They list two bulletins for the mirror shakes and the wind noise. Thought I'd pass it along and it's the last two on the 1999 Ford F150 list. http://www.nhtsa.dot.gov/cars/proble...ervicemmy1.cfm
[This message has been edited by Stihl (edited 12-17-1999).]
Thanks for the heads up Stihl...There is also a TSB for the 2000 model year trucks...here are all 3 TSB's listed for the 2000 model year F-150:
http://www.nhtsa.dot.gov/cars/proble...ervicemmy5.cfm
Service Bulletin Number: 99-14-12
Bulletin Sequence Number: 842
Date of Bulletin: 9907
NHTSA Item Number: SB608428
Make: FORD TRUCK
Model: F150
Year: 2000
Component: POWER TRAIN:TRANSMISSION:AUTOMATIC
Summary: THIS TSB ARTICLE PROVIDES SERVICE PROCEDURES FOR GREEN "PRIOR TO REPAIR" SERVICE TAGGED TRANSMISSIONS. *TT
Service Bulletin Number: 99-6780
Bulletin Sequence Number: 846
Date of Bulletin: 9908
NHTSA Item Number: SB608469
Make: FORD TRUCK
Model: F150
Year: 2000
Component: VISUAL SYSTEMS:GLASS:POWER WINDOW DOOR AND SIDE
Summary: THIS ONLINE SERVICE BULLETIN INVOLVES VEHICLES EXHIBITING WINDNOISE AT THE TOP OF THE DOOR GLASS SEAL / WEATHERSTRIP MOLDING AREA. *TT
Service Bulletin Number: 99-6804
Bulletin Sequence Number: 876
NHTSA Item Number: SB608775
Make: FORD TRUCK
Model: F150
Year: 2000
Component: VISUAL SYSTEMS:MIRRORS
Summary: CONCERNS WITH OUTSIDE PASSENGER OR DRIVER SIDE MIRROR SLIGHTLY FULTTERING / SHAKING AT HIGHWAY SPEEDS. *TT
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
[This message has been edited by Dustoff (edited 12-18-1999).]
Make: FORD TRUCK
Model: F150
Year: 2000
Make: FORD TRUCK
Model: F150
Year: 2000
Make: FORD TRUCK
Model: F150
Year: 2000
KKirt, Good question..I called my dealer along with two others to see if the could use the NHTSA # to ref a Ford TSB...All said no luck ?? Could anybody shed light on the NHTSA sight and how/when Ford would issue their TSB as a result of the NHTSA finding? The only TSB (Ford) that one service guy located was about the mirror shakes but it stated the fix was to remove your bug shield. Apparently Ford feels that is what causes their mirrors to vibrate. Pretty lame excuse.
Where can we get a copy of the solution? I am in the middle of trying everything. Still nothing is working and I don't want to shell out the dough for the dealer to look at it.
'97 F150 Lariat, Flareside, white/sliver, SC, ORP, 5.4 (FQR 8/99) running Mobil 1
Mods: 305/70/16 GY ATS, AR Baja wheels, dual exhaust, Smittybilt Nerf Bars, Edelbrock IAS Shocks, K&N Filter, Carbon Fiber Bug Gaurd and rigged the fog lights too.
