snicker removal
Old Sep 2, 2002 | 06:26 PM
olboymike's Avatar
Question snicker removal
I know I should have had the dealer do this, but I was so excited to get my knew truck, I totally forgot.....How do I remove the dealers logo on the back of my ride?
thanks for your help
Mike
02 crew fx4 lariat
Old Sep 3, 2002 | 09:47 AM
JDMnAR's Avatar
Well - if it is just a vinyl sticker like mine was, it is pretty easy. I just parked it in the sun to let it heat up, and it peeled right off.
Old Sep 3, 2002 | 10:06 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Smile Re: snicker removal
I find that usually a good slap up side the head does the trick.
Old Sep 3, 2002 | 10:10 AM
AjRagno's Avatar
Re: snicker removal
I'm in agreement with, Raoul here. Give that joker an inch and he'll take a mile.
Old Sep 9, 2002 | 10:58 PM
Peacemaker's Avatar
Use gooo-gone. It'll take care of that snicker.
Old Sep 9, 2002 | 11:38 PM
PhillipSVT's Avatar
Let her heat up, then take some strong fishing line and work it back and forth, like a saw, and it should pop right off. I'm going to do this to my truck next time I wax her.
Old Sep 10, 2002 | 09:58 PM
TexfordD's Avatar
un wrap,place between...
thumb and third finger,insert,apply K9s and molers with a chewing motion and swallow
Old Sep 16, 2002 | 01:50 AM
pw1981's Avatar
drive back to dealer, demand removal
Old Sep 17, 2002 | 01:32 PM
bobo21bobo's Avatar
Sticker Removal
It all depends on the sticker. If it is just a sticker let it heat up in the sun and peel it off. If it is a plastic emblem and it won't come off easily with your fingers try using a bondo paddle to push behind it. Once you get the plastic off you can use lighter fluid or some sort of sticker removal compound. After you get all the nasties off wax it. You can also get an eraser wheel that goes on a drill thatbody shops use.
