Installing a billet grille...
Old Aug 26, 2002 | 01:30 AM
LARM's Avatar
Registered User
How hard is it to install a billet grille on a 2002 f-150 xlt supercab? Keep in mind I've never done anything with the body of a vehicle other than installing rain gaurds on the windows. I'm looking into getting one next weekend. Also, I see a lot of them with the oval ford emblem placed on them. Do I use the oval that's on the truck now? And how does that go on? I hope it comes with directions!
Old Aug 26, 2002 | 11:09 AM
02F150n89 5 0's Avatar
Pretty easy
Larm,
I just installed one about a month ago, I have the same truck as you. I got a stull grill, came with pretty good instructions. The only semi-hard part was clipping the plastic tabs off and then sanding them down, becareful that you don't scratch the outer part of the grill guard.
Also, I'm pretty sure that you can use the oval from your original grill, I didn't put one on at all, but I looked at my old one and it is held on by a couple of screws in the back.
Hope it helps you.
Old Aug 26, 2002 | 12:25 PM
LARM's Avatar
Registered User
Thanks...I'll give it a shot. Nice truck, I still have to get some pictures of mine online. How do you like the sound of the flowmasters on it?
Old Aug 26, 2002 | 04:55 PM
2000FordStyle's Avatar
02F150n89 5 0
Just as LARM says. The stull is pretty easy and comes with great directions. I found it easier to score each of the grille tabs even with the grille with a utility knife a couple times and they snapped off flush with the grille. Only had to go back and trim a few with the razor edge. Careful drilling the fiberglass support as you dont want a bigger hole than needed. Otherwise its a easy install. Check http://www.summitracing.com for good cheap prices and fast shipping on these. I believe there is also a step by step install on the SVT boards, do a search on Billet grille on these boards and a link comes up on one of them for it.
Here:
http://www.svtlightnings.com/svt/gri...illetgrill.htm
Its basically the same install and should help some.
Heres mine in a small pic but they look good!!!
Old Aug 27, 2002 | 10:30 AM
Thumbs up Sound great!
Larm,
The flowmasters sound great! Gives it a nice deep rumble. Lets people know I'm coming......................
Old Aug 28, 2002 | 12:37 AM
LARM's Avatar
Registered User
I have another question...I'm going to order the Stull grille this weekend, but I'm confused on what the difference is between a 'grille' and a 'grille insert'? What one am I looking at? Thanks again.
I'm also going to order clear corners...it should look really nice when done.
Old Aug 28, 2002 | 02:34 AM
LARM's Avatar
Registered User
I figured that out heh. I just want to make sure I'm getting the right thing here...this is the part I want, right?
http://store.summitracing.com/partdetail.asp?part=27588
It says 99-01....I have an 02, I'm assuming it will fit on the 02 also?
Old Aug 28, 2002 | 04:01 AM
Larm,
Thats the one I ordered also. Just give Summit a call and they will tell you if it fits the 02. I don`t see why not as there were no changes in the grille at all.
Summit list it as the following on my invoice
STU-5072P Grille Polished F150
Old Aug 28, 2002 | 08:46 PM
TYan323's Avatar
Cool
Besure that your positive on the grille that you want. I just had one installed on my F150. I chose to have the Billet grille without the oval and I really do like it. They do make both grilles, one with the oval and one without but I'm sure that you know that......Good luck. Tom from Dearborn
Old Apr 13, 2021 | 04:08 AM
Aaron W Ahrens's Avatar
Billit grill
How come nobody on Earth can show a video on how to install a billet grill on a 2004 Ford f150 heritage? because there's a thousand videos out there with the Ford F-150 grill being attached to the hood but there's none out there where the grill is attached to the front of the truck. Mine don't have tabs it's all one piece. Can anybody give me a video on how liquid grill is attached to the actual grill frame please?
