Ford removed the Door Crack Preventative Fix!!!!
I took my truck in yesterday to have the door crack preventative fix 'B' accomplished per TSB 01-2-6 and it was their first one they've attempted. They had some questions, so they called Ford and Ford said they deleted/removed the preventative fix from the TSB. The TSB was superseded by TSB 01-18-2, dated 10 Sep 01. I have a copy of the TSB and they did remove Procedure "B" and what was Procedure "C" has now become Procedure "B". Bottom line, there is no longer a preventative fix procedure. The only thing they'll do is fix an existing crack even though it is the same fix! Those of us that don't have a crack currently are screwed!
Has anyone else heard or been aware of this.
This pisses me off as I have 34,000 miles on my truck and I know it'll crack soon after I go over 36,000!
Please let me know where we go from here.
Door cracks
MY truck came back from the body shop on 10/1/2001. Drivers door crack was welded and area was repainted, I think the block was installed inside. The passenger door was not cracked but they must have put a block inside because there was glue stuck to the glass. The body shop this truck was sent to stinks.
. It took 8 days to get the truck back.
