Need Help Removing/Installing...
I need some help. I'm trying to replace my Grill-Surround, which is chrome, with a new one from the factory that is a color-match.
What is the secret for safely removing those funny flat washers on the underside of the Grill-Surround? I have tried everything short of cutting them off and they don't want to "pop" loose or screw loose. What's the answer?
I suppose I'll have to buy a special tool to remove them and then I probably should buy some new fasteners to install the new one.
Thanks in advance for all the help you can provide:
Ditto pa_wolf62.
BV...
I recently did the same surround swap and didn't need any tools to remove those but...
...in the past I have used a wide spaced, two-prong, cooking fork.
Slide it between the two materials being "fastened" and gently twist. The fastener will begin to slide out, you can then wiggle it out with a finger or two.
Use thin cardboard, like a match book, between the tool (fork) and all painted surfaces to prevent scratching as required.
BTW, I was glad to get rid of my chrome too!
XLT_D
BV...
XLT_D
