keys
Old Sep 8, 2013 | 04:42 PM
slwry66's Avatar
keys
hey guys can somebody help. I know this sounds like a dumb question, but when I got my 2011 f-150 I got three keys. Two work to open the doors and start the truck. What does the third one do?
Old Sep 8, 2013 | 04:57 PM
I downloaded the owner's manual and there's nothing obvious in there. Maybe it works in the spare tire lock.
Old Sep 8, 2013 | 05:10 PM
The ignition key works on my spare tire lock. I only got two keys. Can't imagine what the third is for unless maybe the ignition was changed and then it might be for the spare tire.
Sent from my iPhone using IB AutoGroup
Old Sep 8, 2013 | 06:27 PM
canadianelbow's Avatar
Newb posted identical question in 09-12
https://www.f150online.com/forums/20...0142-keys.html
Old Sep 8, 2013 | 07:14 PM
slwry66's Avatar
yep I did. wasn't sure which forum to put it in so played it safe and did both.
Old Sep 8, 2013 | 07:57 PM
aussiekeeper's Avatar
Do all of the keys work everywhere? Generally you will receive 2 keys w/ fobs. Possible you got some other persons keys also.......
Old Sep 8, 2013 | 08:22 PM
We have a rule against cross posting. Just causes too much confusion. When I can get on my computer, I will need to remove the other post as this one seems to be getting the most replies. If you want this thread moved just send me a PM.
Old Sep 8, 2013 | 09:47 PM
slwry66's Avatar
ok That works for me. live and learn.
Old Sep 8, 2013 | 09:59 PM
kingfish51's Avatar
Bluejay, you deleted my post. Shame on you.
Anyway here it is again. If the third key is exactly like the others, then it seems to me it would be a third ignition. If it looks similar, but without the plastic end cap, it may be for a locking gas cap. Since 09 the F150 has come without any gas cap, but many like myself prefer the security of a locking one. Ford has one as an accessory and many have put them on. It is a double sided key like the ignition, but shorter and without the plastic.
Edit - Also, there is a lock in the rear bumper that allows access for the handle to crank down the spare tire. Normally the ignition key is used for this. However, maybe yours is different or has an aftermarket lock.
Old Sep 8, 2013 | 10:15 PM
Sorry about that!
Old Sep 8, 2013 | 10:37 PM
sounds like you got someone else's key
