rusty body mounts
Old Apr 9, 2012 | 11:40 PM
jbloom's Avatar
rusty body mounts
hey yall, i have a 99 flareside that i have a 3in body lift im trying to put on. i got the front cab mount off but cant get the rear cab mount off. the bushing just spin and the bolt wont bust loose. the bushings are in a crossmember so i cant get a pipe wrench on to keep them from spinning like i did for the front ones. any suggestions on what to do? and also i broke the front clip mount bolts off and cant figure out how to get them out of the bushing. Thanks!
Old Apr 12, 2012 | 01:03 AM
wilderthing's Avatar
IMO a sawzall would be your best friend for the rear cab mount.
But the top of the mount might be rusty so be prepared to maybe do a bit of metal work or weld a new washer in place.
Good luck
Old Apr 13, 2012 | 12:35 PM
hscustomauto's Avatar
Cant picture those ones but in thepast if you just cut the bolt you can cut the section of the cab where the mount is and weld a patch there with a new nut welded on the other side.
