4wd bumper
Old Nov 7, 2010 | 08:15 PM
mud boy's Avatar
4wd bumper
There wont be any problems with replacing the lower valence of a 2wd truck with the 4wd valence will there?
Im wanting to do this so i can have fog lights and tow hooks. I think this will be easiest way if it can work
Old Nov 7, 2010 | 09:41 PM
Billymo2's Avatar
im looking to do the same thing on mine, i want hids in the fogs once i get it on there if theres no problem with it.
Old Nov 7, 2010 | 10:06 PM
jtwoodall's Avatar
No problems switching the valances. You may or may not have the wiring necessary for the fogs already. You will also need a new headlight switch with the fogs included.
Old Nov 7, 2010 | 10:28 PM
Billymo2's Avatar
If not can you buy the wiring that's needed? and what kind of switch?
Old Nov 8, 2010 | 06:56 PM
mud boy's Avatar
I all ready have the wiring on the truck. Is buying the new headlight switch the easiest route for power? or can you easily wire a rocker switch to them?
Old Nov 8, 2010 | 08:38 PM
jtwoodall's Avatar
A rocker switch would work, if you want a clean, stock feel, then a new headlight switch is the way to go. Billomo2, I'm not sure about which wiring you would need to buy, but you could check out some wrecked trucks at a salvage yard and pull the wiring. Somebody else who may have bought the wiring afterwards may need to chip in on that.
Old Nov 8, 2010 | 09:12 PM
mud boy's Avatar
Do you know where the rocker switch would wire to?
