Back Window Molding
Old Jun 22, 2010 | 08:09 PM
59fairlane's Avatar
Back Window Molding
The rear window molding surrounding the back window & third brake light is cracked on my 2003 King Ranch. I tried two wrecking yards, but their trucks also had cracked molding.
Does anyone know where I can locate one of these, & could this be a common problem with these trucks? If I can find one near Ontario, Canada, that would be a bonus. Thanks.
Old Jun 22, 2010 | 09:36 PM
Drick's Avatar
Ebay?
Old Jun 23, 2010 | 09:42 AM
fairlaner's Avatar
No advice on where to get one, but keep in mind the reg cab and supercab mouldings are different (mounting bolt locations are different). I'm not sure if the screw uses a different one yet or uses one like the reg or supercab.
Old Jun 23, 2010 | 03:53 PM
_cashel's Avatar
Is this the molding for the slider window, or the whole window surround molding? If it's for the slider window, you're **** out of luck, I ran in to the same problem and NOWHERE has anything that'll just fit right in, and Ford wanted $300 for a new rear window. I told them to shove it and ended up buying a solid 1 piece rear window for $50 at the junk yard. If it's just the surrounding molding, it's really easy to take the rear window out, scrape it off, and reapply it. I forget what the stuff is, but if you go to NAPA or any autoparts store, they should have it if you ask.
Old Jun 25, 2010 | 06:56 PM
59fairlane's Avatar
Back Window Molding
Hi,
Thanks for the info. It is the entire vinyl or plastic molding around the back power sliding window. It cracked right at the side of the third brake light.
