How to Fix a Defective Window Switch
Sorry for the formatting, guys. It's late and I'm tired.
Note: I did this for my 2007 Ford F-150, but it should be nearly identical in terms of process for other vehicles.
Background:
A few months ago my passenger side window switch became defective. It was capable of rolling down the window, but was not able to roll it back up. I had to do it from the driver's side. I could still completely control the window from the driver's side, though, so I knew it was an issue with the switch. It's been a busy semester, so I had decided to put off looking into it until summer.
Well, today I was taking the dog to the park so I had my windows down, enjoying the day. When I got to the park, my driver's side window would not roll up. Same issue as the passenger's side; it would roll down but not back up. It took some playing with to get it to roll back up. In other words, I sat there for five minutes flipping the switch until it went back up. It is supposed to rain tomorrow, so I decided to leave it go until I had more time to look at it.
Sooooo that didn't work out so well. Being the intuitive mind that I am, I decided to check them out. The driver's side costs ~$70 to replace from Amazon, and the passenger's side costs $40, also from Amazon. I don't have $110 laying around to spend on window switches, so I wanted to try it myself. I did in fact figure out what was wrong, and fixed it. The cause of the issue was bad contact points. This is usually the case in terms of window switches becoming defective. All you need to fix this is maybe one or two small screwdrivers, and something to wipe off the contact points with (I used Cu Tips). This is a short tutorial of how to repair defective window switches with this issue.
First Step: Remove Window Switch
This step will vary based on your vehicle. You should be able to pry up a section of door panel to gain access. Just unhook any connectors necessary and use a small screwdriver to pry apart any snap-fits. You only want to be dealing with the switch itself.
2nd Step: Gaining Access to Switch Internals
The switch will likely have two or three sections that are snap-fit together. Use the small screwdrivers to pry them apart until you have the section holding just the switches and contact points. The caps over each switch (with up and down arrows) will pry off easily. After those are off, remove the real switch (white pieces here). These were also snap-fits, so use one of the small screwdrivers to pry them out. Now remove the small metal tabs underneath. These were simply laying underneath, so flipping the whole configuration over allowed them to fall out.
3rd Step: Diagnose your Situation
You may or may not have bad contacts. You will know immediately. If not it is something else, so do a little research and see what you need to do. If you are at this point you obviously wanted to try a DIY fix before paying over a hundred bucks for new switches. It's worth trying to fix while it's apart. If it doesn't work, you're out nothing and you have to buy new switches anyway. Worth a shot, right?
Last Step: Fix it!
It's quite obvious the problem here was bad contacts. All I did was scrape off the crud and afterward wiped the contacts off.
Just do everything in reverse to put it all back together and go test it. For me, it worked for both the driver and passenger sides! Good luck. This is a fairly straightforward fix if you're comfortable doing this.
-Matt
Background:
Last Step: Fix it!
-Matt
