Door Lock
Old Feb 12, 2010 | 09:49 PM
five0merc's Avatar
Door Lock
Not sure but this seems like the place for this one. My drivers side key lock all of a sudden yesterday quit working. It will not turn either way with the key I always use or a brand new one. Any ideas?? Thanks
Old Feb 13, 2010 | 01:53 AM
AAlvis's Avatar
Its possible that the shims in the door lock itself have worn out, get another lock and have it retumbled to your key and give it a try, I know I went through that problem with my truck, had to have it retumbled for it to work.
Old Feb 13, 2010 | 02:11 AM
thejake1989's Avatar
spray some wd-40 in the tumbler. that fixed mine once
Old Mar 2, 2010 | 02:50 AM
orcoastford's Avatar
Tri-flow for locks
I know this is an old thread, but I have some info that I hope will help someone else... I live on the coast where stuff corrodes quick, and I learned from a local locksmith that all he uses in doors with sitcky tumblers or other parts is a lubricant called Tri-flow. He says the oil in it is a good viscosity for lock tumblers, and the teflon keeps working after the oil has seeped off to parts downhill.
I was using this product on residential doors near the ocean and I knew how well it worked. The tailgate lock on my 98 F-150 had been sticky for years, and then my passenger door that I hadn't used in a long time was totally stuck... wouldn't turn at all. I tried tri-flow and they've both worked like new ever since... I now hit them with a little about once a year.
