Gray plastic shroud around rear window Cracked
Old Apr 26, 2009 | 01:49 PM
Marylandboatman's Avatar
I found that plastic shroud around the rear window cracked on the right side of the high center stop light. Has anyone ever changed one of these or should I take it to a pro. Please help!!!!!
Old Apr 28, 2009 | 11:15 AM
Texvet's Avatar
Boatman -
I just replaced the seal going around the rear glass on my 2001 screw. I wasn't difficult - just time consuming. There are 10 or so bolts that hold the trim/shroud and back window in place. Of course - you have remove a fair amount of trim pieces. I wasn't able to remove the trim/shroud, then the window - as the trim seemed to be behind the window frame. Yours may be different, if it's the newer body style.
Short version is - it is doable, just takes time.
