Sluggish Power Window
Old Apr 17, 2009 | 01:49 AM
Zaairman's Avatar
My driver's side power window has become really sluggish lately, but mostly in the DOWN direction for some reason. Going up, it's a bit slower than the passenger side, but nowhere near as slow as when its going down. Any suggestions on what to check? Anything I can lube to make it go faster?
Old Apr 17, 2009 | 02:46 AM
MDK's Avatar
MDK
probably just the motors going bad. Looks like you have a 2000 so that's about 8-9yrs of up and down so I would imagine it's time for a replacement in each window.
Old Apr 17, 2009 | 01:36 PM
Zaairman's Avatar
Damn... I hope not. Anything I can lube in there? I can see how it could be the motor, but it is much slower going down than up... I mean a LOT slower.
Old Apr 18, 2009 | 03:49 AM
MDK's Avatar
MDK
sorry not too sure on what can be done to the internals. I'll have to pass that question onto somebody else.
Old Apr 18, 2009 | 10:24 PM
bwhitehead's Avatar
my 2005 was doing the same thing i ignored it one day the window falls down it turned out the cable on the spool was all tangled up and im pretty sure ill need a replacement unless anyone has any suggestians on how to untangle the cable or get the motor off?
Old Apr 19, 2009 | 02:13 PM
SL3820's Avatar
Well, rip your door panel off(not literally) take a look inside. You could try lubing the regulator and the tract and see if that makes a difference. It could be the switch going out, maybe not giving the motor enough juice. You can rule the switch out by disconnecting it, then by using a battery charger or a jumpbox hook a nail(something conductive) to each clamp and touch the terminals on the wire that go the motor. Or it could be just the motor.
