How do you install toolbox?
Old Apr 12, 2008 | 02:35 PM
buzzsaw714's Avatar
im looking into getting a toolbox for my truck and curious on how to install or how hard it is
Old Apr 12, 2008 | 02:37 PM
MOford21's Avatar
Mainly you just screw them down to the bed. Actually, you don't even have to screw them down, but if you don't it will probably slide around unless there's a ton of stuff in it.
Old Apr 12, 2008 | 02:40 PM
dlsipe1's Avatar
If you do a cross the bed version, there are J shaped bolts that grab the lip of the top of the bed and just put nuts on and tighten down. No need to drill holes.
Old Apr 15, 2008 | 08:23 PM
tequilajohnson's Avatar
I drilled a hole through my toolbox and through the rails and bolted it in. I had the J-shaped clips but they didn't work too well but my toolbox is heavy and has a lot of stuff in it.
Old Apr 21, 2008 | 09:03 AM
flyanbrian's Avatar
It is either the above mentioned j shaped bolts or just regular hex bolts that will bolt it to the bed. Normally 2-4 bolts.
Old Apr 21, 2008 | 11:15 AM
MbL90's Avatar
depends on the box. i have a cross bed so i just have j bolts. my brother has a chest so it bolts to the bed but he uses his bed extender to hold it at the back of the bed
