tonneau cover replacement
My 2000 f150 has finally worn out the factory tonneau cover that it came with. It is the type that slides in place using a track. This setup has worked great for the last 7 years. The cover has been taken off and put back on at least 75 times over the years. The soft cover of the system has finally worn out. Is there a source for buying the cover only or does the entire system need replacing? Thank you.
Hi there. The only places I have checked so far is a local dealership and the online store at f150online. The dealership wanted a lot of money and the online store did not offer just the cover. Will continue the search.
Good luck to you.
regards,
steve
Good luck to you.
regards,
steve
The local dealer has them for $320. I've looked at the Trxedo LP and it's a nice cover. Not sure if I like the inside rails though. I've been looking at roll up only because I throw the dirt bikes in the back so hard won't work but I saw the Extang TriFold and it looks easy enough to remove the whole thing that I am considering that.
any luck finding replacement parts?
I have been looking for replacement corners for my cover. Ford will not tell who made the covers. If you have any information, could you pass it along?
I have a 2002 supercrew, love my truck but stuff has been getting wet since the corner broke.
Donna
Donna
tonneau corner replacement kit!!!!
I was going through the glove box of my truck and found a little plastic baggie!!!
Tonneau corner replacement kit. Part #1403234-2 from Lund (1-888-588-6049). Call them, they will send for free. Other sites list this part around $10.
Can't wait to see if it's the correct part. Tired of getting the wrong part and still have a crappy cover.
They might even have replacement covers, which I might need soon.
