upgrading back window
Old Feb 16, 2007 | 11:50 PM
chrism9232's Avatar
anyone know about how much it would cost to replace my back window with one that has the slide opening window?
Old Feb 16, 2007 | 11:55 PM
there are alot of people that have a slider and want a solid, so you might be able to find someone that will swap with you.
doing the work yourself buying new parts, your probably lookin at 300
dealer installed new parts probably closer to 600
Old Feb 17, 2007 | 12:06 AM
zambonimaxx's Avatar
Have you thought about a power sliding rear window? I have seen that on my friends truck (I have a manual one which I love) but the power option is really cool and saves a lot of reaching for that damn clip...and making SURE its clipped lol. I am not sure how much the auto ones are...but I am guessing (just shooting at the breese) that they are over 500
Old Feb 17, 2007 | 12:41 AM
chrism9232's Avatar
sounds cool how hard would it be to hook up. i would want a factory looking switch in the same place
Old Feb 17, 2007 | 12:07 PM
I have seen it done w/ the wiring going through the top down the A pillar (which is not too hard to do) and then placed into a switch from a contour (I saw that on this forum.) my friend just had a switch on the passanger door next to the driver's side arm (had a 97 so the back door didn't swing out in the supercab). Check w/ the King Ranch moderator.
Old Feb 19, 2007 | 11:43 AM
angus242's Avatar
I found this.
http://www.truckininstyle.com/latemodelsliders.htm
However, I'm sure there are more choices out there. Check with your local auto glass supplier too.
Old Feb 20, 2007 | 01:41 AM
SlammaJamma's Avatar
I have the power sliding window in my truck. If you want a slider, definitely get the power option. With your truck being a s-cab, it will be so much more convenient.
Old Feb 20, 2007 | 01:43 AM
chrism9232's Avatar
im thinking about putting a manual one in but a friend of mine said they are real easy to break in to is that true would you upgrade to a slider? my back window leaks when it rains so i got to do something. i dont want to go to a power one i think it would be hard to make it look factory.
Old Feb 20, 2007 | 01:46 AM
If someone really wants to break in your truck, theyre gonna break into it...period. I think it's just a judgement call.
Old Feb 20, 2007 | 02:02 AM
chrism9232's Avatar
but is it real easy to get in then? my friend has a 90 f150 his is real easy to get in
Old Feb 20, 2007 | 07:01 AM
Unless someone has a slim-jim there is no real way to break into them besides breaking the glass. As mentioned above...if someone wants to break into one THAT bad then hell they will find a way...no if's and's or but's. A solid glass window is just as easy to shatter as a regular window. Secondly that little window is not big enough for me to get into/out of considering my shoulders get stuck before I get half my neck out of the cab, so I doubt that it's even plausible to do. Again it would be way more convinient to have an automatic one especially in a Scab.
~Phil
Old Feb 20, 2007 | 04:34 PM
chrism9232's Avatar
anyone know how much the switch from ford is for the power back window? anyone know it the wires are all ready there
Old Mar 19, 2007 | 07:43 PM
omegasupreeme's Avatar
On my buddy's SCAB, he has the power window, that came with the truck. He has had intermittant problems with it not working. The switch is on the drivers side arm, right by the power windows. As to wether the leads are already run, I do not know, but a dealer could probably tell you. As for breaking in. A criminal will her what they want, no matter what they have to do. They will break a window that gives them a way to unlock the door easily. Ref "Intro to Criminology"
Old Mar 20, 2007 | 11:57 AM
I don't think the wires are already there. Behind my rear seats there is a motor, almost looks like an amplifier.
Old Mar 20, 2007 | 01:42 PM
ws6_guyscrew's Avatar
You might as well get the power slider, here you go,
http://cgi.ebay.com/ebaymotors/NEW-9...rdZ1QQtcZphoto
