How do you install an aluminum fuel door?
Old Oct 6, 2006 | 12:19 AM
mrvandermey's Avatar
Question How do you install an aluminum fuel door?
I just purchased a new billet aluminum fuel door for my 2006 Ford F-150 Supercrew. However, the fuel door did not come with instructions. The fuel door is not a stick-on cover, but a door replacement. The aluminum door has a mounting area with four screws set in four tabs, then there are two set scres above that. However, the stock fuel door does not have any screws. So how do you remove the old door and install the new door? Any help would be good.
Old Oct 8, 2006 | 10:46 PM
ws6_guyscrew's Avatar
On my 2001, I just pulled the little rubber stop out, got a small socket & removed the bolts to the left of the door and pulled it right out, then on the new billet door, got my Hex key and removed the four bolts holding onto the clamps, But the fuel door in place, put the left clamp in and tightened them with needle nose plyers, then same on the right, closed the door, and walla.
