Removing rear seat
Removing rear seat
Im trying to remove the rear seat on my 2005 f150 supercrew....Any 1 know how to do this...I think i can get the bottom part but not the back part.
Im trying to run some wire to the rear taillights for some strobe lights that im adding.. I got the headlights but can't run the wire to the rear, thats why i need to take the rear seats off.
Vic,
I just removed the rear seats on my 01 f-150 super crew and here is what it took, there are 2 front bolts and 2 back bolts per seat. I have the 40/60 sptlit bench in the back seats. When you remove the 4 bolts total, I had to lift each seat up in order to get it to come out. On the rear legs of each seat there is a guide rod on each leg which sits in the floor hole for alignment. Once I got the bolts off and the seat just up a little they came right off. Hope this hepls. Good luck.
Do a search for rear seat removal. There are several treads with pic that help out alot. The first time is tough but, once you do it it's not to bad.
https://www.f150online.com/forums/sh...d.php?t=206580
Try this one.
Try this one.
