Chime
This is more of an annoyance than a problem.
I tend to work outside a lot with my truck near by, and I would really like to be able to leave the radios ( both broadcast and 2-way) on without hearing the warning chime!
I do NOT want to disable the chime, I feel it's very valuable.
I do know about the "screwdriver in the door latch" trick, but am certain at some point I will slam the door shut and damage the latch components.
What I want to do is put a switch inline with the chime so I can turn it off when I don't want to hear it.
Does anyone.. (A) Know the exact location of the chime? (B) Know of a good way of placing a switch inline with the chime?
Thank You,
Rick Critcher
RAC@NYCAP.RR.COM
Thank You,
Rick Critcher
RAC@NYCAP.RR.COM
have you looked at which fuse would disable the chime? perhaps it's isolated on a light circuit which might two fold turn off the interior lights as well as the chime. ?
David
'99 F150 XLT SC, STYLESIDE
4X4 ORP 5.4L, AUTOMATIC,
139wb, Rhino, K&N,
BugGuard, RainGuards
David
139wb, Rhino, K&N,
Leaving the windows open just doesn't cut it!
As for the fuse, the owner's manual doesn't list which fuse the chime is on! My brother said to just take the door apart and find the switch, I just hate to rip apart something that is working well for something so trivial!!
I am heading to a dealer soon and will pick their brains.
Thanks for the input!
Rick Critcher
RAC@NYCAP.RR.COM
Rick Critcher
RAC@NYCAP.RR.COM
Good idea, please post "how-to" and results if you do go with the in-line switch. I might do the same thing if it's not too much trouble.
'99 F-250 LD 5.4L SC XLT 2WD in White/Silver (w/ EVERYTHING 'cept leather and engine block heater) -- added: SnugTop Hi-Liner & carpet kit, Donnelly electrochromatic/compass mirror, K&N filter, SuperWhite 9007 bulbs, IAS shocks, 3" Induction Airbox Mod, more to come... (Westin side bars, cat-back exhaust, electric fan, and Superchip are next)
I agree with Rick, As I have often thought of that very thing. let us all know what you do to remedy this annoying thing!
Ditto!
The chime can drive you crazy! My Ranger was very easy to disable. The chime mechanism was right within reach. Just stuck my hand under the dash and yanked it out.
I guess the switch would be nice but if all else failed no chime would work. When I first got my truck I spent quite a bit of time under the dash looking for the pesky chime! Never could find it.
'97 F150 Lariat, Flareside, SC, ORP, 5.4, Mods: 305/70/16 GY ATS, AR Baja wheels, dual exhaust, Smittybilt nerf bars and fog light mod.
A note of caution I forgot to mention in my last post. When I was poking around under my dash looking for a ignition-only power lead, I was grounding out different wires to see if any would work (BTW never did find one under there -- had to use my autolamp switch). One of the wires I touched and grounded out was the door chime, and it started to sound off. Be VERY careful that you don't accidentally ground out the airbag! I stopped poking around right after finding the chime, and started thinking about what else was there that could go off if I were to ground it out.
Good luck,
Good luck,
Thanks for all the interest!
I've enlisted the help of some folks that I think can help, we're going to talk Friday.
When I do get this finished I will make a post here to describe what we did.
Rick
RAC@NYCAP.RR.COM
Stock'98 F-150, 4.6L, SC, A.R.E. MX Cap
Rick
RAC@NYCAP.RR.COM
Go here for that fix:
<HREF = "https://www.f150online.com/f150board/Forum53/HTML/000369.html">https://www.f150online.com/f150board/Forum53/HTML/000369.html</A>
2001.5 SuperCrew XLT 4X4
Silver Clearcoat Metallic
Deep Wedgewood Blue (accent)
5.4L V8
Chrome Tubular Step Bars (Ford)
Captains Chairs
Power Moonroof
3.55 LS
6750 GVWR
Class III Towing Pkg
Mods:
Harley Davidson Exhaust
'01 Lightning Head/Tail Lamps
Pioneer DEH-9200r
Boston Acoustic Components & 5X7s
Box Liner (Ford)
Splashguards (Ford)
Bug Defector Doubles as Rock and Sand/Salt Deflector in these snowy Canadian winters
To Come:
17" Rims/Tires
K&N Air Filter
5.4L V8
Captains Chairs
Power Moonroof
3.55 LS
6750 GVWR
Mods:
Pioneer DEH-9200r
Box Liner (Ford)
Splashguards (Ford)
To Come:
17" Rims/Tires
K&N Air Filter
