Laeky rear window
Old Feb 28, 2001 | 04:24 PM
troj's Avatar
Post Laeky rear window
I have a 97 f-150 xlt extended cab. Rear window has a slider. Rear window leaks bad from top of window (not slider). Dealer says I need a new window cause window frame is bent from cab flex or heat (design flaw?). Anyway, I think I can fix it for $2 in caulking if I can get the rear molding off the truck. Has anyone removed this before? Do I need special tools? Im out of warranty and $500 for a new window can be used somewhere else. Thanks
Old Feb 28, 2001 | 05:02 PM
Flatlander's Avatar
Smile
You can try that, it just unbolts. There's a few different methods of fixing them on the board here, as there are many that have had this problem. I had mine sealed like you're describing (I think), which lasted for a couple months. Then it started leaking again at the crack (passenger side at top). I filled the crack with super glue and black gasket sealant from inside the cab, and it hasn't leaked in a while. Good Luck and welcome to the board!
'97 F-150 Lariat SuperCab 4X4
  • White/Silver, 4.6L, Auto.,Open 3:55
  • Tinted Windows/Bedmat/Toolbox/Lund Bug Deflector/Ventvisors/Extra Horns
  • 265/75/16 BFGoodrich AT's on polished 16x8 AR-136's
  • Cat-back Dual Exhaust (Straight pipes with big chrome tips)
  • Black Polar Bear Grille Guard
  • Cranked Torsion Bars for 1" Lift
Old Mar 2, 2001 | 10:26 PM
ringmaster's Avatar
Post
i have the same problem with my back window on my 98 i talked to fords and they told me there is a service order on that to im getting mine replaced next week.
Old Mar 5, 2001 | 07:49 AM
troj's Avatar
Post
Hey ringmaster, thanks for the info. What is meant by a "service order". Things got ugly with the dealer last week before I left. Major denial that they have seen or heard of this problem before. Should I contact someone else, like regional rep? It just sounds like this is a problem on this truck.
Whatever happened to quality is job 1. This whole ordeal has soured me.
Troj
Old Mar 5, 2001 | 10:47 AM
ringmaster's Avatar
Post
im not sure but when i went to see about getting the door cracks fixed i talked to the service manager and he told me that there was a repair out for it. it isnt a recall or it dosnt fall under warrenty its like ford knows about it and when someone complains about it then they will fix it. i didnt get any problems from them at all
Old Apr 4, 2001 | 04:09 PM
jwill1's Avatar
Post
Mine leaks also. I was told I'd need a newer version replacement window. Now I'll head for the dealer. Thanks for the info.
97 SuperCab Flairside XLT
4.6 AODE-W Shift Kit
Straight Pipes
