Rear window
I have a 1997 F-150,and want to know if anybody has had problems with there rear sliding window leaking through the seal and plastic.and if this is a problem like the crack in the doors,and yes I have a crack in my door to.
Hey I got those leaks too. How come they don't recall defects like this?
KV
'97 F150 SuperCab 4.6L Auto 2WD
Burgandy
Nerf Bars
Cat Back exhaust with Magnaflo dual 3" pipes
and tipsout the back.
SuperChip
K&N Drop-In Filter
Bosch Platinum +4 spark plugs
1/4 16.747 @81.73 (this will improve)
Track Time Pics
KV
Burgandy
Nerf Bars
SuperChip
K&N Drop-In Filter
Track Time Pics
Fella's go to the Search feature and try something like 'rear slider leak', or 'window leak'.
There's probably 15 gadzillion posts, more information than you can stand.
Your eyes will pop out of your head and you will weep, if that's possible.
I've been wondering why mine doesn't leak. I even have my CB antenna wire going through the gasket,and it still stays dry. Freak of assembly,maybe? Maybe you leakers could tell where it's leaking from,and we could compare differences between our sliders. I have noticed that the gasket has a gap where it meets the corner at the latching side.(two different pieces) The bottom window track also has a lip on the outside(would collect water) In my opinon this,and the gasket gap would cause a hellacious leak,but mine doesn't. Is this where yours are leaking?,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Stillen Quad light air dam, sweet!!
Euro taillights
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper alarm
On the way/wheels,tires, etc..etc.......
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
Mine doesn't leak but its been ratteling a bit for the past week.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
4.6 Triton Engine
sliding rear window
My rear window leaks to. I have decided to use some rope caulk on the outside of the truck, around the inside lip of the top of the window (if you can picture it)... I will let you know how it turns out.
i have a 98 ex cab on both sides of my slider window i have a crack where i think water got in and froze to break it it leaks also its annoying but i deal with it till i get my cap to take it out for good.. also i have the same cracks on both of my doors at the bottom corner of the window edge..
I just spoke to my local Ford Dealer ( Northside Ford - San Antonio, Texas) and the service agent said that he could replace the rear window slider assembly for a $50 deductible as long as the miles were less than 50K. He said that it would be retrofitted with a newer style that would not crack or leak again.
Just a quick FYI and question. I week ago I discovered that my rear sliding window leaked above the headliner(not the window itself. When checking the bolts that secure the window( 4 bolts total), I noticed they were pretty "loose".
I tightended them, but was wondering if there is a torque specification--so I don't over tighten????? I didn't see any cracks in the frame itself(fingers croseed). I hope this fixes the leak.....I'll keep you posted.
F-150 4X4 XLT Supercab
Black w/ Gray trim
5.4L Triton
Class III Towing
3.55 LS
Gray interior w/ Captains's chairs
6 CD Changer
285 75 16R BFG's
Black w/ Gray trim
5.4L Triton
Class III Towing
3.55 LS
6 CD Changer
285 75 16R BFG's
HELP!!! I have a 1998 F150 XLT with a solid rear window. The other day it started leaking (driping) above the passenger area. When I looked outside, I notice a small crack above the glass in the seam (plastic area). I took it to the dealership (because It's still under warranty) and they said they would have the glass removed and resealed. My thought is, how will that fix the crack in the plastic. He also told me, that if it leaked again, they would replace the entire glass/frame assembly. I feel that the entire assembly should be replaced, not just a "cheap fix" -- as they put it -- (yes, that is what they called it). They said they wanted to do the least expensive thing first, and then replace it if needed. Does this sound right??? I paid good money for this truck and don't want to have a "cheap" fix under warranty. I told them to put it on hold, and I'm going to take it to another dealership for a second opinion. Ok, with all that said, WHAT IS YOUR OPINION as to the correct fix for this window leak???? I know this is a known issue on many 1997+ F150's. My "second opinion" appointment is on 01/26/2001. So everyone's feedback would be really really apprciated. THANK YOU SO MUCH.
Mr.Ryan
Mr.Ryan
<font face="Verdana, Arial" size="2">Originally posted by RyanKarr:
</font>
</font>
<font face="Verdana, Arial" size="2">Originally posted by aypstony:
</font>
</font>
</font>
</font>
HEY!! They are going to replace the entire window assembly, under the "bumper-to-bumper." They didn't hesitate to fix it right, the first time. Rochester Auto Collection in East-Rochester is the BEST!!
Mr.Ry
Mr.Ry
