Removing mirrors
Old May 29, 2004 | 12:41 AM
jcs03F150HD's Avatar
Removing mirrors
I have to replace the whole mirror assembly since thieves stole the mirrors(funny they only took the mirror itself) so I ordered a complete replacement lower profile mirror. So far I have removed the door panels, unscrewed the three nuts holding the mirror, and disconnected the connectors for the mirror and light bulb turn signal. I have the two small connectors completely out of the housing but the large black connector for the turn signal bulb is hard to get out.
Old May 29, 2004 | 01:01 AM
Here's the connector I can't remove.
Old May 29, 2004 | 01:03 AM
mirror
Old May 29, 2004 | 01:16 AM
sleddogg's Avatar
jcs, That link says sorry also. Be glad they just stole the mirror part. To take the hole thing would mean gaining access to the cab, inwhich case the truck would probably go with the mirror.
Sled...
Old May 29, 2004 | 01:21 AM
oops let me try again.
Old May 29, 2004 | 12:03 PM
Old May 30, 2004 | 10:27 PM
sleddogg's Avatar
jcs, Still not working. Post the pic in your gallery and then post it here. Your puter is saving that address so you can see it, but we cant.
Sled...
Old May 30, 2004 | 10:43 PM
Hope this works:
https://www.f150online.com/galleries...3757&anum=6240
Old Jun 3, 2004 | 10:26 AM
MN-Trap's Avatar
JCS, Remove the cable from inside the door. Factory mirrors come with cable already attached to the mirror. It's really easy to get to if you carefully pull down the thin foam paper from the top of the door near the window opening.
Old Jun 3, 2004 | 05:55 PM
Is this the connector?
connector
Old Jun 8, 2004 | 10:30 AM
MN-Trap's Avatar
Sorry I didn't get back to you sooner. I do believe that's the correct connector. I can't remember but is is easier to remove/install with the window up or down.
Use the instructions at the Muth site:
http://www.kwmuth.com/products/kits/200-0002-6.htm
Old Jun 21, 2004 | 12:39 AM
madferraristi's Avatar
Sorry to steal you thread but I have a related question posted earlier in the electrical forum--
Can anybody verify, for absolute certain that this power mirror plug is the same as the OE on a 2002?
